series60
- Jan 4, 2010
- 420
I've read everything I could find but still unclear about the wire connections for installing Pertronix electronic ignition kit #2842 in an AQ125 with
Bosch distributor # 0231 178 017 JF4. I removed the old points, ballast resistor wire and grommet from inside the distributor and reconnected the resistor to the original position on the side of the dist. I left the wire running from the neg side of coil to the resistor connected. There is an exposed bayonet connector which is part of the ballast resistor assembly. I will cover this exposed terminal. I ran the Ignitor wires through the hole left in the dist housing after removing the original wire. I then ran the red wire to the + side of the coil and the black wire to the ? side of coil.
I would like conformation about this before I connect the battery and hit the start switch!
Thanks, Bill
Thanks, Bill
