Hi all,
I sure hope someone here can help me out. My 91 Glastron Volvo 230A is overheating at high RPM? I know, this again?! I?ve tried everything guys.
Any suggestions would be immensely appreciated?
- I changed out the impeller.
- I removed the exhaust manifold to inspect it. Found it practically brand new. No rusty chunks inside and the zinc plug looks ok. These exhaust manifolds don?t have risers, so I flipped it upside down and stuck my water hose in the intake hole and watched as the manifold filled up. No water ever entered into the exhaust ports. Not even a trickle. The water filled up the water jacket and started pouring out of the end where it ejects out the exhaust pipe end as per normal.
- The thermostat seemed to be working well but just to be safe I popped and locked it in the open position.
- I flushed out the heat exchanger. Removing the line that leads to the exhaust causes it to instantly drain. There is no restriction. I placed a water hose in it at high power and the thing drains water out really fast. It even looks nice and clean inside. The cooling lines that run to the engine seem good too because when I flush that out it also drains like a champ.
- I replaced the gasket to the water neck on the outdrive.
- The outdrive water neck was slightly corroded, so I sanded it down lightly to make it smooth and applied a thin coat of sealant around the neck so it would mate well with the S hose. That failed miserably too
- I considered that the problem may lay in the seals of the outdrive. Some have found the plastic bushings around the water tube (where the pivot yoke is) to break or develop pin holes that cause air to be sucked in. I can?t afford an outdrive rebuild, so I drilled a nice hole in the bottom of my boat and installed a water intake strainer bypassing the entire outdrive system and gooseneck and plumbed it straight to the impeller intake side.
- No, there is no water in the oil
- Yes, it actually is overheating. It is not the temp gage. I know it is because it will lose power and the heat exchanger overflow and cap will start spewing yellow coolant steam
