flyingscott1962
- Apr 27, 2014
- 23
Okay that may not be an accurate title but I am having problems assembling my lower unit and pump housing on my 75hp Scott motor.
I have not ran it and this is about how I received it. I added new driveshaft needle bearings but that's it. Everything turns fine in each gear as it should until I tighten the bolts holding the pump housing and the LU together, the they both essentially lock up. When there is a 1/32" gap they turn fine but when the gap closes it gets more tight.
What is happening when I tighten that last hair down? What can I be checking?
Thanks
Tyson
Thanks
Tyson
