1968 ESKA 5 hp Spark Plug and Fuel/Oil Mixture Questions
kcsguide
I recently acquired a 1968 Eska 5 HP, model 1185, SN: T-634-07E is stamped on a plate on the engine and resembles a SN but the data plate is blank where the SN used to be printed. I've been going through it and see that the starting instructions say to mix 1/2 pint per gallon of fuel. Really?? That's a 16:1 ratio?? Can anyone confirm that it takes that much oil? I'm just used to 50:1 as an industry standard. The second question is about which spark plug it is suppose to have. On one forum I saw someone say that it requires a Champion J13Y gapped to .025 and in another forum someone said that it takes an RJ13 gapped to .030. Does anyone have that information?
Thanks in advance for your help!
brim_buster
J13Y gapped at .030 and 69 models 16:1 and 70 models 24:1 per the service manual
