TinCanCaptain
- Dec 7, 2014
- 12
Hey guys. I've been roaming the forum and am learning tons from all of you. I have a problem I can't find any topics anywhere on. I just purchased 14' richline semi V to take the family out and it came with a broken 7.5hp gamefisher. The gentleman I bought it from said he pulled the boat out of the water with the motor down and the gear housing and leg were broken along with bending a stud and the drive shaft.
The problem I'm having is removing the driveshaft to straighten it or to try to find a used one. I've removed two retaining clips on the prop shaft(inside the housing) but when I pull on the shaft the assembly gets hung up on the clutch. Any help would be greatly appreciated. Thanks in advance.
Motor is a 1986 gamefisher 7.5 hp model # 217-586753
