I recently posted a thread trying to get my Sears 3.5 running. I was successful and took the motor out for a roughly 30 minute trip. There and back it was fine. I stopped for a little while and then continued running it. The motor then started to misfire (if that's the right term) occasionally. Since fuel was starting to run low, I tilted the tank so that there was definitely plenty of fuel. This did not help. I stopped the motor, waited a while, and started it up again. It ran extremely rough. I was able to get home at idle speed, but if raised above that the motor gets rougher and rougher. Today I tried a different spark plug and adjusting the carb settings. No luck. Also, the motor seems to be smoking more than usual. This is a video of the motor showing the condition: http://youtu.be/rr_JxNy_NaI
The audio doesn't capture the sound very well. The best way I can describe it is that the motor (when working correctly) hums, it started popping occasionally the other day, and now at idle it hums and pops, and at higher throttle it just pops.
Thanks in advance for any input!
