I tried the search option but petcocks come up way too often. I recently picked up a 3hp Gamefisher made by Tanaka. The PO fired it up and it ran fine. I brought it home, drained the fuel to fix a small crack in the task, changed the gear oil and spark plug. It started and quickly died. I couldn't start it again. I verified it has a spark. I checked the fuel line to the petcock and it's clear, so is the line from the petcock to the carburetor. But no fuel flows through the petcock regardless of the position of the petcock lever. Should it or is there a vacuum that pulls it through? Thanks in advance, Mikeg
