Have a 3.5 hp 1972 sears outboard that starts fine but won't rev right past idle. If I throttle up past idle it will rev a little/bog/rev a little/bog. The carb was cleaned out and I tryed fiddling with the float level. I replaced the spark plug. I tried adjusting the jet on the bottom of the bowl and it makes no difference in operation until the jet is so far in that the motor dies from no fuel at all. Adding a little or a lot of choke just makes it run worse. Should I check compression? I have no idea what numbers to look for. I'm somewhat stumped and need some input. Thanks in advance. unior
