Trying to find some tips on installing the lower crank seal on a 63 5hp gale built Sea King. I ordered a new plate, gasket, o ring, seal, spring, etc. Does everything slide over the drive shaft and sit on the roll pin, then install? Any tips?
I purchased the motor and upon removal of the powerhead found that the seal was missing. So I can't use the install in reverse order of disassembly trick.
Thanks for everyones help.
