boxchevyman
- Mar 16, 2014
- 61
I have a Wizard 3.6 hp made by Scott-McCulloch. I recently got it running and it runs pretty good just doesn?t pump water. I took the lower unit apart and the Rotor type pump looks old but still intact, the little leg is still there and it seems to make contact with the sides. So then I took the power head off and chucked a drill up to the drive shaft and ran it but I didn?t see anything coming up through the water tube, which was clean. So it certainly points to a water pump being bad.
So I guess my question is do these Rotor style pumps go bad to the point of not pumping water at all? Or do you guys think I have another problem going on here?
Thanks a bunch
James
Thanks a bunch
James
