Model # GG18732B
Serial # 36X877796
Recently acquired this motor has good compression and spark. Pulled powerhead and dropped lower unit.
Parts list that I am looking to purchase:
Head gasket
Impeller
Water pump gasket
Lower seals in prop housing look fine but would like to have spares.
I was wondering if there was a diagram available for LU I only see one gasket at the water pump and I'm not sure if there are supposed to be more. I did not find a gasket in between the lower and upper half of the LU when it dropped not sure if it should have one there or not. If there are any other seals or gaskets I should check or replace fee free to chime in.
Was curious to know what would be the best way to clean prop housing gears and shafts...Brake cleaner? WD40?
Any help finding compatible parts would be great.
Thank you in advance.
Serial # 36X877796
Head gasket
Impeller
Water pump gasket
