1965 Sea King 6hp 19073
buddhapi
first question; was this a pre Chrysler model? I'm needing a lower cowl piece that the hood latches down to. before I took possession of this motor, it was dropped and broke a chunk out. the hood is fine.
2nd question; what other years, makes and HP models will interchange with this white motor I have? I know there may not be too many people here that can answer this, so I'll be patient.
I can use this motor as it sits, but I'd sooner not get laughed at, at the dock. thanks you all for any help you can give; Gregory
brim_buster
Re: 1965 Sea King 6hp 19073
It should be a Chrysler. According to Langs chart its a 65 which Chrysler started making them in 64-65. As far as what will interchange with it I havent a clue.
buddhapi
Thank you for the reply. that should make it much easier fr me to find the parts I need:)
F_R
This should be your motor. I see similar covers for various motors as new as 1971.
buddhapi
Thanks for the paperwork F_R. now I can see the part number to search for. much appreciated!
buddhapi
thank you F_R! I see the exhaust gasket #59 in the page 3 page view. there is also a gasket underneath the support plate. I was wondering if you had another parts list with the mid section? thanks for any help I can get....
F_R
No Title
Still working on it after two years, eh? That's patience.
Here ya go----
