staplesofficewar
- Mar 2, 2014
- 6
Hello All.
New boat owner here...Kinda excited, but also a little intimidated.
My father-in-law left us a 14' Duranatic with a 15 HP gamefisher outboard on it. I see all kinds of info on the web, but I am unsure of what applies to this motor...Force? Chrysler?
Model: 225.581501
serial: 4485
I am not sure what year this thing is...the title for the motor says 1999, but I think that may be incorrect. I changed the impeller and the gear lube since it had been setting in Texas for the past 5 years.
I used this impeller:
Sears Gamefisher 9 9 15 HP Water Pump Impeller Model Number 225 | eBay
I drained the lube...it looked OK and filled it with gear lube. I greased all the linkages and changed the spark plugs.
When I run it in a barrel, it seems there is ALOT of white looking foamy grease in the water...
looking into the water when it is running, I see air bubbles and possibly those white greasy foam coming from a small hole - maybe 1/16" diameter or more - in the side of the gear housing....does this indicate a problem? I would not expect all this gunk from a few minutes of running.
Is there a "pee" hole on this unit? The only water I see spraying is from the exhaust relief ports.
Thanks for any and all help!
Model: 225.581501
serial: 4485
