My throttle does not return the mag advance all the way to low speed idle. The cam has a step in it and carb roller does not make it to the step down. As a result it idles high. The threaded adjustment at the rear of the recoil is adjusted all the way in and the mag idle stop screw is all the way in without popping the plastic cap off.
Do the throttle cables tend to stretch? Am I missing something?
