Idahogobbler
- Nov 9, 2013
- 17
figured out my fuel starvation problem bad gasket and pin hole in the diaphragm got that all fixed! Now water problem....
Took the lower end off looks like impeller is brand new ware plate looks good how tight should the 4 bolts go on?? when engine is startred it does not pump water out any were??? there are 2 or 3 holes right on the back that just blows air is this the **** holes or exhaust?? also theres no hoses or anything from lower unit to any were I guess I don't get how impeller throws water all the way up just in open space maybe im missing something??? block starts getting very hot so I shut it down before it gets to warm any ideas???
Colton
Colton
