1968 eska 7.0hp impeller change
ray 6688
Hi all
I need some advice please.
Can anyone tell me how to change the impeller on this motor?
The motor is fitted with a f/n clutch, so can I just drop the gearbox to access the impeller,
or will the clutch parts stop the drive shaft dropping down the leg.
Will I have to remove power head to un do anything first
Thanks for any advice.
Ray:confused:
brim_buster
Re: 1968 eska 7.0hp impeller change
do you have any serial or model numbers?
MahtyMaht
If you have a clutch, it's set screwed onto the crank, and the drive shaft plugs into the bottom of that. Post a model number.
ray 6688
Hello
Sorry about the delay, but I had to go over to the boat to fetch the motor at the weekend.
Its now in my garage, so easy to work on.
Model # 1717 Serial # 550961
Hope this helps
