Hi guys, I just aquired a 73 Ted Williams #217.58760 15 H.P.
I have a question about upgrading the ignition system. I've seen posts here and several other places about rebuilding these parts, but it's kind of confusing with which parts they are talking about and so fourth.
Sandbagging around other parts of the web, I've seen people replace their ignition systems with some sort of ECM; mainly one called Nova II Amazon.com: ELECTRONIC TRANSISTORIZED IGNITION MODULE NOVA II: Patio, Lawn & Garden
These systems along with a matching coil, have been replacing older outboards/tractors etc. with a point/condenser system.
Now, these Ted William's have a SSI setup with 1 magnet on the flywheel and one trigger magnet in the center hub of the flywheel; which can be easily removed. Does anyone see why I wouldn't be able to use this Nova setup to use on my Eska? I really don't see any difference between the SSI and the point setup except for the style of electronic parts. If you remove all the electronics from both styles of engines wouldn't it be the same? Just a magnitized flywheel attached to a spindle, add the coil, get it lined up, attach the ECM and hook up to spark plugs.
Any thoughts?
Thanks,
Jeff
Any thoughts?
Thanks,
Jeff
