Re: eska 7.5 hp water pump replacement
Model number would help here. If you have a shift lever, there's a two screw oval plate on the port side of the leg above the lower unit. Yank that plate and there's a joint in the shift linkage retained by a single screw. pull the screw to separate the upper from the lower linkage. Power head will leap off into your hands. When you get it off, you can put he lower unit in a bench vise clamping on the skeg. The first thing the drive shaft goes into is the pump housing, retained by two nuts. yank'em and you have the impeller.
