KillerKilgore
- May 29, 2010
- 46
This motor a 1979 7.5hp sears hasn't been started in over 2 years. Cleaned and THOUGHT I set the points right but it wants to kick back when it starts. Using 40:1 fuel mix.
There was a triangle on the cam roller. I put the points arm just to the left of the cam roller is that right?
But I found this post that for a 69 5hp that said to use the lines on the cam.
http://forums.iboats.com/other-outb...eska-5-hp-217-58520-a-626415.html#post4370211
There are lines on my cam as well as the triangle. didn't know which to use because of the different in the years
Like the OP in the thread I mentioned above does it make a difference if the piston is TDC or not?
Does it make a difference where the throttle is placed?
Thanks in advance
Kilgore
Thanks in advance
Kilgore
