Trying to get the float level set to the spec height. I know the proper height and the bend the tab method to set it. My problem is that i cannot get it to the spec level. The inlet needle seat is down all the way and there is no debris under it to cause the height issue.. I have the tab bent as much as it can go. I am still 2x higher than what it should be. Without the inlet needle seat i can get the proper height. How important is this little red character? Please help.. Any thoughts or suggestions.
