Re: Fuel pump Kit 1960 25 HP electric start Gale outboard (22DE17BL).
Assuming the motor has the original fuel pump, that pump is obsolete and no parts are available. Simply replace it with a Sierra 18-7351 pump, available right here at iboats. The hoses will have to be re-routed, but you were going to replace them anyway, right?
EDIT: You shouldn't assume the pump is bad simply because the glass bowl doesn't fill. If gas cannot get into the carburetor for some reason, it will be blocked from flowing to it (via the bowl). However, the pump is 53 years old and it is reasonable to think it has lived a good life and deserves to die.
