I Just Bought This Outboard From A Friend Of Mine. I Was Wondering What Kind Of Gear Oil Should I Use And What Is The Proper Fuel And Oil Ratio. This Is The 7.5 HP Tecumseh PowerHead
Re: Sears and Roebuck 217/58589 gamefisher outboard
The gear lube plain-jane 90 wt gear oil. I think the ratio is 50:1 because the crank has needle bearings. Bet you're going to have to kit the carb. Don't turn it over without grounding the plug or the plug wire, you'll burn down the solid state ignition, and you gon't want that.
That's where Sears gets their parts anyway, and unlike Sears, they are not shipping rapists. The plug is an Champion J13Y gapped at .030". As for literature, join here - eskaoutboards : Eska Outboards Group
