I bought a chrysler wiring harness pre-wired on one end to the ignition and i wirednthe other end to the engine using this wiring schematic in the manual. There is no spark coming from the spark plugs(starter kicks on strong, it trys to start). When i was holding the coil with the plug attached to watch for a spark there was none. When my thumb was accidently touching the metal of the plug when starting then i felt and saw a spark, but only when i was touching it. Something to do with grounding? All the engine wires that are supposed to be grounded are securely to the engine. But on the wiring schematic, the harness goes to what looks like a ground block first and then from there to the ignition. I have it directly to the ignition. Could this be it,? I circled the part in the photo that i DO NOT have. Thank you in advanced, Mike(first time boat builder and outboard wiring!)
