Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
3 hp Tanaka/Gamefisher idling and prop issues
This topic is closed.
  • 3 hp Tanaka/Gamefisher idling and prop issues
    Hi all. After many, many years of trusty, reliable service my little 3 hp, air-cooled Gamefisher kicker motor is acting up. I believe the centrifugal clutch may be worn/broken as I can now spin the prop in either direction, even with the motor turned off, whereas I was unable to do so in the past. As a result, the prop spins even at the lowest idle settings. I used to be able to set the idle so low you could practically count the rpm without the prop engaging, then as you rolled on the power, the prop would engage and off you go. Now, the prop spins no matter what, and I can't get the motor to idle down like I used to despite multiple carb cleanings and fuel line inspections. It also bogs down and hesitates slightly when giving it more throttle, but I think that may be a separate issue. It's now as if the clutch is permanently engaged. It works great at higher rpms and can run WOT all day without issue, but it no longer idles like it used to. Is there any way to remove the power head to inspect/repair the clutch itself? I'd hate to have to get rid of it, but it may cost more to fix than its worth. Thanks for any help.
    Re: 3 hp Tanaka/Gamefisher idling and prop issues
    I too have this motor but i just bought mine used. from my understanding the clutch is pretty easy to get to. beleive its the 4 screws on the bottom. as far as what to do once ur in ther is another story. my clutch seems to work properly but cant get it to stay running. I have pulled the carb off and cleaned it and everything looks in pretty good condition. do u know where to get replacement parts for it?
    • #3
      I've my TOB300 for a long time as a trolling and "get-home" motor. Aside from being an ultra light, its also a very reliable motor. Dropped it once and cracked the plastic shroud ( which I removed, now I can see the level of gas in my tank), cracked the flange on the carb intake, cracked the gas tank( can only fill it halfway now), and damaged the vent on the gas cap. I have been searching for a while for parts source with no luck 'til I came across this website OEM Parts .You might want to give this a try.
      • #4
        it is as easy as you say to get to the clutch. I did find the clutch material for the small flex metal clutch not connected, I epoxied it back to the spring steel. BUT this is a discontinued part, does any one know of a place to get replacements. Right now I will let it set for 24 hrs to test with epoxy, I have done that before with good results.
        • #5
          4+ years old. Start a new thread.
          Closed.
          BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
          Please, no PM's (Private Messages) regarding boat/engine problems.
          That is what the forums are for.
          Only forum/moderator issues will be answered in PM's.
