Montgomery Ward Sea King/Clinton 5 hp info needed.
ronboonville
Good morning, I just purchased a 5 hp monkey ward sea king 5hp, 1973. I don't find any parts breakdown on this motor. It is a k500. Only $35. and comes with tank and line which will be delivered later, so I can't see if I can start it. good compression and not beat-up at all. It appears to be air cooled, I think. It really has the title, and it came from original owner. Anyone know anything about these motors or a source for points and condensor? Hope I didn't buy something I can't get parts for or tech info. I'm not sure what possessed me to buy it since I don't have an extra boat to put it on.
jim j geezer
Re: Montgomery Ward Sea King/Clinton 5 hp info needed.
Cheer up. You could get lucky.
Plan on cleaning the points.
In order to do that it's likely you'll have to tap the flywheel holes to accept a puller.
Clean the carb.
Replace fuel lines.
Water pump impeller replacement will improve your vocabulary.
Yep. It's air cooled. Mostly. But it uses water cooling too.
