KICKEDBACK
- Aug 15, 2009
- 10
Howdy, I have had a good but trying adventure with my 3.6. This motor was made the same year I was born and I like that fact alot. It is running but has a occasional "klunk" type miss while speeding it up. I removed the fly wheel and spotted what looks like a mouse took a bite off the top edge of the coil. I cleaned and set the points (.020) and filled the "chomp" with liqued electrical tape and it is just a little better. I am wondering if a 2 part epoxy would be O.K.? I think it is shorting to something under the fly wheel. If this is a "do not do" then has any one substituted the coil with another and if so what did you use.
The lower unit and I had a grand adventure, but today with about 1 hour of testing, that is in good shape too. On a 46' /462 series the prop cover is on the prop side and after extensive searching I believe it was a bad design and why mine was cracked in half in 2 places. Trying to weld it did not work but as I am 1/2 okie I fixed it by stacking aluminum...1/4" plate with a 3/4" pc and a seal plate of 1/4" also. If I knew how to add a picture I would be embarresd as all the shaping was done on my shopfox metal band saw. The bushing hole and the seal hole was done at a machine shop but all else was at home. Its crude but works perfect.
I think the space ship gas tank is beautiful and not being a purist I will repaint the entire motor soon...I'm thinking a bright orange for the tank and flat black on the fly wheel and rope start, silver power head and gloss black on down. Hey! I like Halloween colors, it's my BD.
I wanted to share my day with a motor that was given to me. Hope everyone has good days too.
