serialdata
- Feb 27, 2012
- 2
All,
I have been a menber here for a while and I have enjoyed all of the info that you guys provide. I usually can find what I need by searching, so I have not needed to ask a lot of questions. However, I just purchased a decent running Gale Model # 25DE21BL and SN 881118. It will be a great running motor once I clean the carbs and correct the ignition issues, which are both very small issues. I found where 25DE21B is a 25HP Buccaneer from 1963, but could not find a number that has an L following it. I hope L doesn't stand for "Lemon"! Is it just one that was imported from Canada in 63 to cover the shortfall in the US? If so, can I assume the part numbers and manuals will work? Thanks for any help you can give!
