Wolfs_hell
- May 20, 2010
- 10
I have a sears gamefisher, 15 hp, buy force. model number 225-581506. i had to dismantle the power head due to a fuel/air leak at the lower crank shaft seal. My questions are as follows:
#1 all the diagrams I can find show an o ring above the lower bearing cage at the bottom of the block. However, when i took everything apart, there was no o ring. So, do I need the o ring or not, and if I do, where do I put it?
#2 when I put the cylinder block back together, i beleive that after degreasing I have to re-seal it with Permatex #2 non hardening sealent, do I coat the entire serface where the block and the cover go together?
#3 and finally, can i replace the cylinder block screws that hold the cover and block together, both the 4 larger and 8 smaller, with hex head screws/bolts without messing anything up? I have seen other mechanical applications that you could not change screw head types. I ask because the slot headed screws are a pain in the but to take out and torque back in.
Thanks in advance
Thanks in advance
