Has been a weird sound in the engine after I serviced it.
a knocking sound follows the engine speed, but with a much lower frequency.
the knocking noise comes about once a second, at lowepeed (25-30 knots) and more frequent when the speed increases.
The sound seems absent when I have it in neutral and rev the engine.
No unusual noises in the prop shaft when I spin the propeller.
No play in the prop \ propeller shaft.
The only thing I have done with the boat before the sound came are: replaced impeller, shaft grease,.
No chips or water remaining in the oil I drained off.
The engine starts and spins and run just fine. Going well and is quick in response.
Shift is fine without any noise, slippage of some sort.
All answers are appresiated
