jimbobcooter
- Feb 27, 2012
- 78
Ok so I bought a used B&S 5hp outboard a few months ago and it had minimal use. I went ahead and replace fuel lines, filter, and changed the oil. I took it out and ran it for 2-3hrs. It ran great, started every time no problems. Seeing as how it is winter her I have been going out once a week and starting it and letting it run for until it is hot. Everytime I use it I let it run out of gas for storage purposes.
Today I went out for a little while. But beffore doing so I bought a new fuel cell. Once out on the lake I ran to my fishing spot with no problems.
Later I picked up a friend and we TROLLED around for about 30mins. With a few spurts of half to full throttle. Once I droped him off I went to run back to my fishing spot and she took off just fine. She ran full therottle for about a minute and then died like she ran out of gas. It that time I noticed the vent on the new fuel cell was closed off. When I opened it air clearly pulled in and the tank expanded a little.
After tryin every combo of choke and therottle I finally got it started again. I limped back to the marina and she was running rough. All she would do is idle. If I gave her any gas she would die. After being at the marina for a while I was able to get her to idle rather smooth. When I gave her gas in N she didnt stutter. So, I took of for home again and she ran for a while and died again.
I was only able to get her started again using a 1/4 choke. I was able to make it 15-20min back home with at 3/4 throttle and 1/4 choke. When I got close I tried reducing the choke and she died and has not started again.
I have checked the fuel filter and plenty of fuel is getting thru it. I also pulled the carb bowl and fuel is getting to it. The spark plug has a min amt of moisture on it.
Could it be the period of idle? Did I ruine the fuel pump? Could junk have pulled into the carb?
Any ideas would be appreciated!!!!
