BaconGrease
- Feb 7, 2012
- 4
Hi,
New forum member here. I have read through many of the frequently asked questions and previously posted topics but i cannot find help for my problem. I have a tanaka 1.75hp that will only run if its left on choke and if you give it too much gas it then wants to sputter out. I have tore the engine apart and cleaned the rings, opened the carb and let it soak and blew out all of the junk, I have replaced all fuel lines, replaced the spark plug, and made a fresh batch of gas oil mix to use. I cannot figure out what the problem is. This is starting to frustrate me. It worked great the last time I had it running which was about two years ago. I did drain all fuel before storing it.
