I just bought this motor off of craigs list and had the guy start it up and the engine ran fine. He said he only used it one weekend and had no problems. So bought it got it home and the motor will go from neutral to reverse but not to the forward position. I have not tried this while running. I live in an apartment complex and they wouldn't like me to run it on the patio. I plan on taking it to my in-laws and trying it there. Has anyone had this problem. It just will not physically move to forward.
Thanks,
John
Had to re-post this because it was closed and the only semi help I got was this: "give a little pull on your starter rope while you wiggle the shifter and see if it will go into forward" and the oil subject. Currently I don't feel it is an oil issue because it was just changed and the shifter mechanically will not move to forward. I will mount it on a stand or something and try the advice of a little pull to see if I can get it into forward. Any other ideas would be GREATLY appreciated.
John
Thanks,
John
John
