Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Sears - Gamefisher Outboard Motor 1.75
  • Sears - Gamefisher Outboard Motor 1.75
    I just purchased a used "Sears - Gamefisher Outboard Motor 1.75" and need a little help!
    Here is the info I have,
    Model: 298-585180 SN C042321 Do I need oil in the lower unit? if yes what type and brand works best!
    Do I need to grase anywhere?
    Does anyone have a copy of owners manual they can share?
    Thanks for any help, StarGazerI
    usadco@comcast.net
    Re: Sears - Gamefisher Outboard Motor 1.75
    Any gamefisher with the 298 prefix is made by Tanaka.
    Schematics
    http://www.searspartsdirect.com/part...dMod=298585180
    Still looking for a manual...
    I'm not sure about the gear oil. I see in the gear case section of the sc hematics that it has parts number 38 and 39. 38 says drain gasket/seal so it's possible.
    Have you taken a compression test or spark test?
    I would grease alittle around the transom clamp bracket and mabey the part where the tiller connects to the engine. Other than that if it just gonna be fresh water use just spray it down with the hose when done. If it gonna be saltwater lightly grease every bolt/screw from the lower unit up to the mid section.
    DamianJP
    "Idling like a clock and pissing like a race horse." -DamianJP
    • #3
      does the lower unit have two screws?? any lettering around them?? if it does it might say vent on top and fill on the bottom. if so yes it does have gear oil, a good indication if it does is unscrew the bottom something should come out i would hope. i fill my 1976 eska from sears with 80-90w gear oil i use valvoline and change it offten. esspecially if it leaks
      • #4
        Thank's DamianJP.
        1. Have you taken a compression test (YES)
        2. spark test? (YES) all good
        There is 3 scerws on the lower unit.. 2 to hold the caseing and 1!! Dont know?
        Thank your for your answers and questions. Im still hopeing to find a manual!!
        Thanks Again! StarGazerI
        • #5
          Thanks axeman! It only has 2 scews for holding plate on and 1 screw (I dont know what its fore). and still looking for a operations manual.. Thanks again! StarGazer I
          • #6
            if i'm thinking the what your seeing you are looking at an inspection plate just above the lower unit.
            if it is an inspection plate the bolt you see in there could be (like in my case) the gear shifer does you outboard have forward N Reverse? for me i have an eska and right above the inlet holes for my impeller is a vent screw for the lower unit lubricant and at the bottom of the unit by the prop(not really like 4 to 5 inches away) near the back is a larger fill screw. does your gamefisher have any of the things listed above?
            • #7
              Hi Axeman! Thanks for the input but, it doent have a Reverse.. just forward to go into Reverse, you rotate motor 180 deg. LOL Thanks for the input StarGazer I
              • #8
                no problem hope you got the gear lubricant all sorted out. i'm 95% sure yours does have some lubricant in the gear drive.
                • #9
                  Hey Star
                  Can't find a 1.75 owners manual (Yet...), I have the same 1.75 and have been looking for one for abit too.
                  But Iv'e found the 120 (1.20HP) one...
                  http://www.tanaka-usa.com/pdf/manuals/TOB-120_300.pdf
                  Says this...
                  Gear Housing
                  Check gear housing for proper level of grease after first 4 hours of operation
                  and every 50 hours thereafter. See Storage section for annual maintenance.
                  To check and fill unit with gear oil, pull motor out of the water and place in an
                  upright position. Remove spark plug wire. Remove housing drain plug and
                  washer. Insert nozzle of lubricant tube fully into hole and squeeze tube until
                  excess oil flows from around nozzle. Replace plug and washer. Tighten securely.
                  NOTE: Use 90 weight Hypoid Gear Oil.
                  Page 12 of the first link to the whole manual. Seems the screw by itself is the fill and drain all-in-one.
                  DamianJP
                  • #10
                    Thanks GOOD INFO!! Ill keep you all posted too! Best Regards StarGazer I
                    Just found this too!
                    Did you know!
                    Tanaka air-cooled, all two-stroke outboard motors were manufactured by Tanaka Kogyo Ltd. Co. in Japan from the mid-1970ôs until 2002. They were produced under 3 different brand names
                    Tanaka, Sears Gamefisher and Aquabug. There were different colors and labeling configurations, but within each horsepower rating (1.2 HP, 1.75 HP, 3 HP and 5.5 HP) the motors were identical except for the shroud / decals.
                    • #11
                      Good stuff man !
                      • #12
                        Good News!!!! Found manual and parts too!
                        http://www.searspartsdirect.com/part...00032189/00002
                        I purchased a bunch of stuff and Manual.. When I get it I will "YOU KNOW" so send me an email address to use! usadco@comcast.net
                        Best Regards, StarGazer I
                        P.S. Hey I use to live in Palm Beach for 20 years too.
                        • #13
                          Hey! got the motor cleaned up and started grate and adjusted carb so blade stops at idle. Manual was a god-send. I removed all gas-lines and carb and gas filter and did a total cleanning and replaced carb float only.
                          Hows yours comming? Best Robin
                          • #14
                            Sorry about inbox full, I emptied it abit so feel free to PM for now.
                            Well unfortunately my Gamefisher 1.75 is on the back burner for now. Iv'e got a buddies Evinrude 25hp and my BMW to do before I "dig" into my tanaka. I might need some more parts for it than I thought but It will be fun to get it %100. Nice on just having to replace the float , saved ya some money.
                            I'll let ya know when I focus on the tanaka and how it turns out.
                            BTW what kind of boat are ya thinking of hanging yours on?
                            DamianJP
                            • #15
                              Damian, Plan to use it on my NEW PUFFIN 8.6' dinghy from Maine..LOL Need some help though! Please check your Spark Plug and tell me what is in yours! Also, sent you a email outline of your Lower Unit too. Need info ASAP!!
                              Robin
                              Back to Top
