I have acquired a 1967 9hp Ted Williams/ Mcculloch Md# 574-59740. Have rebuilt the Coil/Ignition to get spark. Cleaned the carb. It fires but does not stay running. Have a Elgin/Mcculloch 7.5hp and ran into same problem but was given info to set carb settings back to factory. I wanted to know if if was the same here on the Idle and Rich/lean setting? Any other advise would be helpful. Thank you.
