i have been trying to troubleshoot this engine four about five months and i am clueless. I've checked compression and spark on both cylinders and have found nothing out of specs. the motor will run great in a tank or on back of boat out of water with water running through engine. When we put it in the lake the motor will run in nuetral at all rpms with no hiccups at all, when shifting into gear the motor under load will not come up to that sweet sound of a smooth running engine like it is in nuetral. it will slowly come up to speed then will bog down under load ie running in forward then it dies. i start the engine up, it will purr like a kitten in nuetral shift into gear slowly come up to speed then die. I have gone through the carb and found no dirt or obstructions, we have tried running the motor at various different needle positions on the carb and have similar results. we had ignition testers on both cylinders and have good spark.needless to say i am pulling what hair i have left out of my head trying to think what could be the problem. fresh gas good compression good spark runs in tank not on back of boat in gear. any help would be greatly appreciated thanks
