Hello! I am new here and am seeking some advice. I have a 1968 4hp Mcculloch air cooled S/N 82090-11 that i got from a family member and it has been sitting for who knows how long. I cleaned out the gas tank and carb and installed a new fuel line. I installed a new spark plug and put fresh gas in mixed 50:1. I have a carb rebuild kit ordered from discount marine parts. The engine will start and idle but when you try to accelerate you will get what i think is a lean pop. Its not backfiring through the carb but making a popping sound at upper rpm's which causes the engine to die. It will idle as long as you want it to though. This engine also has what looks like advanced timing when you accelerate. Would a lean pop situation be solved by my carb rebuild kit that i have ordered or does this sound like an electrical issue? Thanks for any help.
