Re: 1947 2G2 5hp Goodyear Seabee
I figured it out, but anyways I wanted to take the powerhead off to make it easier to paint everything, especially since I could slide the clamp up and off.
I haven't tried to run it yet, but I'd assume that being 64 years old with no signs that it has been gone through- I should check the seal and condition of the lower unit, check the ignition for cracked coil and rotten wire, de-gunk the fuel system, and make sure the cooling channels are unobstructed before giving it a chance?
I got the 1947 Gale 2G2 Goodyear in a package deal with an Iowa farmer along with a 1964 lightwin johnson and a 1988 6hp Force for $125. I got rid of the Force (made by US Marine) right away because it seemed like a real Walmart special although it ran fine. The lightwin is fully restored and a cool machine. I saved the most difficult for last. Now to pop the flywheel off.
I actually pulled some of the threading out in the Johnson's flywheel by using a 3 bolt puller- then ended up giving up after heat, prying, and tapping on the shaft w/ a rubber mallet didn't work. I saw through the inspection window that the ignition components looked fine so I stopped before doing something really stupid.
