I have an old 4.5 horse Eska lower unit. I am looking at a new B&S engine, 4hp, shaft is 7/8" x 1 13/16", a log splitter or pressure washer replacement motor is what it is tagged as, heavy flywheel, no brake. I plan on making an adapter or mounting plate out of aluminum plate to match the engine to the lower unit.
the problem is coupling motor shaft to the existng lower unit shaft
the lower unit drive shaft is splined, appears to be 7/16" in diameter. I also have the original coupler, splined on one end, and the other end has a keyway, 5/8' hole. the origninal coupler is 1 1/8" in diameter. my original thought was to bore the coupler out to 7/8" but that means that collar is only going to be 1/8" in thickness, and there would be no keyway. there's not wnuf metal left after boring out for a new keyway.
looking at Lovejoy jaw couplers, anyone use them???
open for any and all suggestions, solutions.
I want to get this project going. gonna be crappie season soon!!!
