1970 Eska 1715B Golden Jet 500 ( Tecumseh AV600-643-05A Powerhead )
ckswanecamp
ckswanecamp
Re: 1970 Eska 1715B Golden Jet 500 ( Tecumseh AV600-643-05A Powerhead )
TECUMSEH POWERHEAD AV600-643-05A
1 Diagram: AV600-643-05A Engine Parts List Tecumseh 310218B
"Rod Assy., Connecting Not available
2 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650633
Screw, Connecting rod Your price: $2.10
0 of these in your cart Qty:
3 Diagram: AV600-643-05A Engine Parts List Tecumseh 650704
Washer Not available
4 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 530104A
Bearing, Cartridge Your price: $15.54
5 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 310283A (replaces 310269A)
Piston & Pin Assy. Your price: $30.84
6 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 310289A (replaces 310190)
Ring Set, Piston Your price: $14.58
7 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 310178
Pin, Piston Your price: $9.08
8 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 310296 (replaces 310167)
Ring, Piston pin retaining Your price: $1.90
9 Diagram: AV600-643-05A Engine Parts List Tecumseh 290409
Crankshaft Not available
10 Diagram: AV600-643-05A Engine Parts List Tecumseh 250242
Block Assy., Cylinder Not available
11 Diagram: AV600-643-05A Engine Parts List Tecumseh 530137
Bearing, Needle Not available
12 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510242
Seal, Crankshaft Your price: $4.55
13 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510243
Retainer, Crankshaft seal Your price: $6.00
14 Diagram: AV600-643-05A Engine Parts List Tecumseh 510244
Ring, Crankshaft seal retainer Not available
17 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650579
Screw, Int. torx hd., 10-24 x 1/2 Your price: $2.10
18 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510274A
Gasket, Cylinder head Your price: $2.18
19 Diagram: AV600-643-05A Engine Parts List Tecumseh 250270
Head, Cylinder Not available
20 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650477
Screw, Torx pan hd., 1/4-20 x 3/4 Your price: $2.18
21 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 610830A
Resistor Spark Plug (Champion RJ-12YC or Your price: $3.03
22 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510270A
Gasket, Reed plate Your price: $4.55
23 Diagram: AV600-643-05A Engine Parts List Tecumseh 470139A
Plate Assy., Reed Not available
24 Diagram: AV600-643-05A Engine Parts List Tecumseh 570630
Ring, Ball bearing retaining Not available
25 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650700
Stud, Carburetor Your price: $2.10
26 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510105
Seal, Crankshaft Not available
27 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510106A
Retainer, Crankshaft seal Your price: $4.55
28 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510109A
Ring, Crankshaft seal retainer Your price: $4.55
29 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510217A
Gasket, Carburetor Your price: $2.10
30 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 29752 (replaces 650457)
Nut, Flange whizlock, 1/4-28 Your price: $2.20
31 Diagram: AV600-643-05A Engine Parts List Tecumseh 570469
Bracket, Control Not available
32 Diagram: AV600-643-05A Engine Parts List Tecumseh 570425
Rod, Idle adjustment Not available
33 Diagram: AV600-643-05A Engine Parts List Tecumseh 570486
Rod, Choke Not available
34 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 570406
Spring, Choke rod Your price: $1.55
35 Diagram: AV600-643-05A Engine Parts List Tecumseh 650584
Screw, Hex Socket hd. set, 6-32 x 3/1 6 Not available
36 Diagram: AV600-643-05A Engine Parts List Tecumseh 490280
Link, Choke shaft Not available
37 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650229
Screw, Pan hd. Torx, 10-32 x 3/8 Your price: $2.10
38 Diagram: AV600-643-05A Engine Parts List Tecumseh 510268A
Gasket, Housing base Not available
39 Diagram: AV600-643-05A Engine Parts List Tecumseh 350367A
Base Assy., Housing Not available
40 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 530105
Bearing, Needle Your price: $11.82
41 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650561
Screw, Hex washer hd. Durlok, 1/4-20 x 5/8 Your price: $2.18
42 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650496
Key, Flywheel Your price: $2.18
43 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 610118
Cover, Spark plug Your price: $4.64
44 Diagram: AV600-643-05A Engine Parts List Tecumseh 610121
Clip, Cable Not available
45 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650579 (replaces 650618)
Screw, Pan flex hd., 10-24 x 3/8 Your price: $2.10
46B Diagram: AV600-643-05A Engine Parts List Tecumseh 410235
Tank, Fuel Not available
47 Diagram: AV600-643-05A Engine Parts List Tecumseh 650747
Screw, Hex washer hd., 1/4-20 x 3/4 Not available
48 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 590416
Cup, Starter Your price: $9.96
49 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650815
Washer, Belleville Your price: $2.18
50 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650390
Nut, Jam Hex Your price: $2.18
51 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 29752 (replaces 650457)
53 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 29634 (replaces 28837)
Strainer & Fitting, Fuel Your price: $6.04
54 Diagram: AV600-643-05A Engine Parts List Tecumseh 570468
Stop, Control lever Not available
55 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 27070
Washer, 1/4 lock Your price: $2.15
59 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 29774
Line, Fuel (8-1/4" long) Your price: $4.88
59 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 30705
Line, Fuel (16" long) Your price: $8.11
59 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 30962
Line, Fuel (32" long) Your price: $12.62
70 Diagram: AV600-643-05A Engine Parts List Tecumseh 610281
Screw Assy., Friction Not available
73 Diagram: AV600-643-05A Engine Parts List Tecumseh 570430A
Cam Not available
74 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650423
Washer Your price: $1.50
75 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650545
Screw, Torx pan flex hd., 6-32 x 3/8 Your price: $2.10
76 Diagram: AV600-643-05A Engine Parts List Tecumseh 570487
Lever, Control Not available
77 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650579 (replaces 650618)
83 Diagram: AV600-643-05A Engine Parts List Tecumseh 650504
Screw, Pan hd., 6-32 x 3/4 Not available
84A Diagram: AV600-643-05A Engine Parts List Tecumseh 570490
Spring Not available
85 Diagram: AV600-643-05A Engine Parts List Tecumseh 610808
Washer, Insulating Not available
86 Diagram: AV600-643-05A Engine Parts List Tecumseh 570153
87 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650423
Washer, 5/16 Flat Your price: $1.50
88 Diagram: AV600-643-05A Engine Parts List Tecumseh 610809
Wire, Cut off Not available
89 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 650742
Nut & Lockwasher, 6-32 Your price: $2.18
91 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 30548B
Condenser Your price: $7.31
92 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 30547A
Contact Assy., Breaker Your price: $9.24
93 Diagram: AV600-643-05A Engine Parts List Tecumseh 631505
Inlet Needle & Spring Assy. Not available
96 Diagram: AV600-643-05A Engine Parts List Tecumseh 631600
Carburetor Not available
97 Diagram: AV600-643-05A Engine Parts List Tecumseh 610832A
Magneto Not available
98 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 590420A (replaces 590420)
Starter, Rewind Your price: $63.64
99 Diagram: AV600-643-05A Engine Parts List TEC Tecumseh 510295A
Gasket Set
ckswanecamp
Carburetor Tecumseh 631030
1715B Golden Jet 1970 5 1 Carb Kit DI-52030 Tec 643-05A
1 Diagram: 631600-CA Carburetor Tecumseh 631030
"Shaft & Lever Assy., Throttle Not available
2 Diagram: 631600-CA Carburetor Tecumseh 631045 (replaces 630810)
Spring, Throttle return Not available
3 Diagram: 631600-CA Carburetor Tecumseh 631552
Shutter, Throttle Not available
4 Diagram: 631600-CA Carburetor TEC Tecumseh 650506
Screw, Rd hd 4-40 3/16 Your price: $1.53
5 Diagram: 631600-CA Carburetor TEC Tecumseh 630738
Spring, Main adjustment screw Your price: $2.18
6 Diagram: 631600-CA Carburetor TEC Tecumseh 630953
Element, Pump Your price: $9.38
7 Diagram: 631600-CA Carburetor Tecumseh 631268
Shaft & Lever Assy, Choke Not available
8 Diagram: 631600-CA Carburetor Tecumseh 631048
Spring, Detent Not available
9 Diagram: 631600-CA Carburetor TEC Tecumseh 630758
Shutter, Choke Your price: $2.10
10 Diagram: 631600-CA Carburetor TEC Tecumseh 630748
Plug, Welch Your price: $2.05
11 Diagram: 631600-CA Carburetor TEC Tecumseh 650569
Screw, Rd hd 6-32 3/16 Your price: $1.55
12 Diagram: 631600-CA Carburetor Tecumseh 631505
Inlet Needle & Spring Assy Not available
13 Diagram: 631600-CA Carburetor Tecumseh 631506
Spring, Inlet needle Not available
14 Diagram: 631600-CA Carburetor TEC Tecumseh 632019A (replaces 631023)
Float, Carburetor Your price: $9.09
15 Diagram: 631600-CA Carburetor TEC Tecumseh 631024
Shaft, Float Your price: $2.05
16 Diagram: 631600-CA Carburetor TEC Tecumseh 631949 (replaces 631332)
Bowl & Drain Assy, Float Your price: $8.02
17 Diagram: 631600-CA Carburetor TEC Tecumseh 27136A
Plunger Assy, Drain Your price: $4.58
18 Diagram: 631600-CA Carburetor TEC Tecumseh 27554
Gasket, Drain plunger Your price: $1.83
19 Diagram: 631600-CA Carburetor TEC Tecumseh 631553
Screen, Filter Your price: $3.63
CARB PARTS
20 Diagram: 631600-CA Carburetor TEC Tecumseh 632259A (replaces 631554)
Gasket Not available
21 Diagram: 631600-CA Carburetor TEC Tecumseh 631334A (replaces 631334)
Gasket, Bowl-to-body Your price: $3.93
22 Diagram: 631600-CA Carburetor TEC Tecumseh 631861 (replaces 631343)
Adjustment Screw Assy,Main Your price: $10.20
23 Diagram: 631600-CA Carburetor TEC Tecumseh 630740
"O" Ring, Adjustment screw Your price: $2.60
24 Diagram: 631600-CA Carburetor Tecumseh 631271
Screw Assy, Idle adjustment Not available
25 Diagram: 631600-CA Carburetor TEC Tecumseh 631028A (replaces 631028)
Gasket, Bowl-to-body Your price: $1.93
26 Diagram: 631600-CA Carburetor TEC Tecumseh 631555
Valve, Flap Not available
27 Diagram: 631600-CA Carburetor Tecumseh 631556A (replaces 631556)
Cover Assy, Valve Not available
28 Diagram: 631600-CA Carburetor TEC Tecumseh 630739
Washer Your price: $2.18
29 Diagram: 631600-CA Carburetor Tecumseh 631335
Shot, Lead Not available
30 Diagram: 631600-CA Carburetor TEC Tecumseh 650699
Screw, Pan fle hd, 4-40 3/8 Your price: $2.05
33 Diagram: 631600-CA Carburetor Tecumseh 631373
Repair Kit
ckswanecamp
IGNITION
IGNITION PARTS
on diagram Image not available Flywheel
Number:610751We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Image not available Spring, breaker box
Number:30551We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Image not available Cover
Number:30550Substitution:610947Manufacturer authorized substitution: 610947 may differ in appearance, but is a functional equivalent to prior parts including 30550.
$3.14 In stock
Quantity:
Add to cart
on diagram Image not available Cam, breaker
Number:30552We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Contact assembly
Number:30547ASubstitution:33-606Manufacturer authorized substitution: 33-606 may differ in appearance, but is a functional equivalent to prior parts including 30547A.
$8.73 In stock
Quantity:
Add to cart
on diagram Image not available Washer, terminal
Number:610385We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Nut 8pk
Number:610408Substitution:STD541008Manufacturer authorized substitution: STD541008 may differ in appearance, but is a functional equivalent to prior parts including 610408.
$2.16 In stock
Quantity:
Add to cart
on diagram Image not available Screw washer
Number:29181Manufacturer authorized substitution: 29181 may differ in appearance, but is a functional equivalent to prior parts.
$3.14 In stock
Quantity:
Add to cart
on diagram Image not available Screw, condenser fastening
Number:610593We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Image not available Coil
Number:30560ASubstitution:33-363Manufacturer authorized substitution: 33-363 may differ in appearance, but is a functional equivalent to prior parts including 30560A.
$30.96 In stock
Quantity:
Add to cart
on diagram Image not available Wire, lead
Number:30554We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Image not available Condenser
Number:30548ASubstitution:33-008Manufacturer authorized substitution: 33-008 may differ in appearance, but is a functional equivalent to prior parts including 30548A.
$5.40 In stock
Quantity:
Add to cart
on diagram Image not available Core & plate
Number:610736We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Image not available Stator assy. (incl. nos. 2, 5 thru 11, 13, 14 &...
Number:610858We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
on diagram Image not available Felt, cam wiper type 1631
Number:30549Manufacturer authorized substitution: 30549 may differ in appearance, but is a functional equivalent to prior parts.
$3.14 In stock
Quantity:
Add to cart
on diagram Image not available Clip
Number:31311Manufacturer authorized substitution: 31311 may differ in appearance, but is a functional equivalent to prior parts.
$3.14 In stock
Quantity:
Add to cart
on diagram Image not available Screw assy., friction
Number:610281We're sorry. This part is no longer available. No alternate or substitute part has been recommended by the manufacturer.
M
mrcrabs
Guest
:facepalm:thanks
Clemsontiger
I love it! :) A bunch of thanks.
