Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Gale Carb Rebuild Help...
  • Gale Carb Rebuild Help...
    Just got my rebuild kit in for my 1960 Gale 25hp outboard. The motor uses OMC parts as most of you know, and takes carb pepair kit #439075. This carb and kit is used any many other models, one being the 1975 Johhson 40HP.
    Was expecting it to come with diagrams and instructions since my dad's 06 Johnson 25hp did when he rebuilt his carb, but it did not. Was hoping someone could point me in the direction of the step by steps of the procedure and diagrams for this. If any of you have this information and wouldnt mind to email it to me I would very much appreciate it! Thanks in advance guys!
    Re: Gale Cart Rebuild Help...
    The top secret file listed under the Johnson/Evinrude group has some good info.Hope this helps.
    • #3
      Re: Gale Carb Rebuild Help...
      It probably would be a good idea to pick up a shop manual. If you're quite mechanically inclined, then a Seloc would be good enough. Get the Volume I if you do. If you are a rookie mechanic, then get the certified factory manual (which costs twice as much as the Seloc)
      You'll find that those carbs are easier to rebuild than removing them from the manifold. It's just the matter of getting them cleaned thoroughly and re-assembling the packings on the needle jets correctly. If you're neat and meticulous, you'll do just fine.
      Admiral Zephyr
      1941 Johnson HD-20 (in restoration)
      1947 Sea King 5hp
      1948 Evinrude Sportsman
      1951 Evinrude Fastwin
      1955 Johnson CD-12
      1955 Johnson RD-17
      1955 Evinrude Big Twin
      1956 Johnson RD-18
      1957 Evinrude Big Twin
      1958 Evinrude Fisherman
      1958 Johnson FDE-12
      1959 Johnson RDSL-21B
      1974 Tanaka 1hp (screamin' drink mixer )
