Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Sears/Force Gamefisher 15hp 1988
  • Sears/Force Gamefisher 15hp 1988
    I have a 15hp Gamefisher 1988 model #225.581500, and it runs like a champ. Have a two blade prop currently, considering swap to three blade. The Gamefisher is currently powering a 12 ft aluminum - along with an electric trolling motor - used primarily for lake trolling trips. I read other posts on prop selection, saw the info on TinyTach to assist with performance/tuning monitoring. Which begs the question - what is max safe RPM for this outboard?
    Thanks in advance - iboats forums have been VERY helpful.
    Re: Sears/Force Gamefisher 15hp 1988
    I have a 1988 15hp Gamefisher, and the coil is bad. Do you know where I can get parts for this motor? Any suggestions/help would be appreciated! HELP!?
    • #3
      The 225 model prefix is a Chrysler Outboard, you might try asking at the
      Force & Chrysler Outboards forum,
      SEARS MOTORS with Model Numbers other than 217.???????? where built by:
      225.?????? Chrysler Outboard
      574..????? McCullock Outboard
      Parts for McCullock Outboard are No Longer Available
      Some Parts for Chrysler are avalible on special order only.
      http://home.earthlink.net/~brixent/searsid.htm
      • #4
        Max rpm is 5,750.I think you may have trouble finding a 3 blade prop.I think prop selection may be pretty limited.Its possible the correct 3 blade might do better with a load its likely the lightly loaded speed could be less. 3 blades have more drag.
        Check your motor height.The antivent plate (just above the prop) should be about even with the bottom of the boat.Should be visable on plane.Could slightly improve speed,hole shot and handling.
        • #5
          WE are having this exact same problem! Any luck finding parts?
          Back to Top
