Re: 5hp Briggs and Stratton outboard won't start
Okay, I have finally found someone that has trouble starting their Briggs. I have had mine for 5 yrs and have had problems with it right from the start. The motor can sit in the garage on a stand all winter, and come spring I can hook up the fuel line and 1 to 2 pulls it will start right up and run fine. The problem is, when I get it on the boat and run it across the lake, shut it off by first putting it in neutral and then hitting the kill switch, then try to restart it, it won't start. It doesn't even sputter or backfire or anything. Now, this is not my first outboard, nor is it my first Briggs product, but, it is very frustrating to have to row back to the dock, with blisters on your hand from trying to start the motor. The blisters are not from rowing. I have contacted the Briggs people, and they recommended to adjust the neutral switch. I have done this, and the motor will start. Now, if this is the problem, how does it get out of adjustment? By just shifting from neutral to forward and back to neutral? Also, I have asked them if the motor should have spark in forward or reverse. Their reply was that it should have spark only in neutral when trying to start. I have spark in any gear, but the motor will not start until I play with the neutral switch adjustment. Crazy.
Does anyone know how to disconnect the neutral switch, to see if this is the problem?
Once the motor will start, it runs great.
Just maybe, we might be having the same problems. (sorry if I stole the thread)
