i bought this motor on line, engine runs great, the prob I am having is the one speed trans. I have taken it apart two dozen times. should be simple but I can't get it. the prop shaft is spring loaded and it seems to prevent the shaft from fully engaging the trans. if i tap on the shaft it engages, however in the water the pressure pushes the prop aft and the gear will disengage. help please.
