reelfishin
- Mar 19, 2007
- 3,043
I came across a new in the box Tanaka 3 HP that I wanted to use on a small jon boat. I took it for a test run the other day and it did fine but every so often while running near or at wide open trottle, the motor just quits, like it ran out of fuel. It restarts instantly and runs fine. If I run at half throttle it runs fine but surges a bit once in a while, I checked the carb, filter bowl and tank, all look fine. The tank vent is a manual screw cap and is clear. The fuel is mixed at 50:1 as in the manual and it runs great up until the abrupt shutdown. It gives no warning, just quits. The part that gets me is that it starts right up, not even a full pull gets it going again and it runs for another half hour or so fine, then it does it again. It's working pretty hard, but pushes the boat about 12 to 14 knots and sounds fine. I have tried just about everything with no change, had anyone had any experience with one of these? I was thinking that maybe the carb or float isn't keeping up with demand or maybe the needle and seat are getting stuck? The part that has me puzzled is that it restarts so instantly and continues.
