Re: Tanaka 300 help
In my book it is described as a clutch shaft it is cup, shaped and appears seperate from the shaft.
Looks like the shaft is square doesn't look like a spline.
There is a small snap ring that appears to go under the bearing and a large snap ring that appears to go above the bearing.These may hold the bearing to the bottom of the cup.It appears the bottom of the clutch case may be a clamp that tightens around the bearing
thus holding the cup in place in the clutch case.Otherwise I see no way to hold the cup in place.
You might look in the cup for a bolt that may attach the cup to the shaft but there is no indication of such a thing.
