Re: NEPTUNE 1948 1.5 h.p.
I Don't know if you'v ever hear of AIROCROIL Its another spray type penetrating oil, Ive used it and its top notch for freeing up these old stuck motors, I use a map gas torch to heat the cylinders hot, very hot! then spray in the pen/oil then heat try to move flywheel I use a 2x2 and 3 pound hammer motor needs to be flat on a hard cement type floor clockwise then counter-cw once you get movement your on you way! heat-oil-hammer....heat-oil-hammer,, when you get your first full revolution. stop it is time to celebrate!!! now is the time to consider your next step if you have access to a large air compressor you can use a impact driver to see if you can get a slow steady spin, if not mount the engine to something solid and get the pipe and socket, I prefer a wrench and pipe to the socket. go SLOW""" be happy for each movement you get and switch directions often, It took me 9 days to get a very rude evin-rude 25 hp un-stuck this motor sat face up carb mouth wide open thru a very long wet winter, today she runs fine.
she loves a man with a slow hand
