I'm testing this motor out before I buy it and found this milky mixture leaking from the top hole in the lower unit. While running the motor, it shoots clear water from the hole. When I shut it down, water runs out followed shortly afterwards by this milky mixture. Not sure this is a seal/gasket leak or an overfill situation? Is it a easy repair? Any advice/suggestions are greatly appreciated. the white milky mixture will also come out of the lower hole later on. Thanks!
