I have a 6hp seaking. In a bucket of water it will rev up to full speed, and in gear it will rev up as well to full speed (have to be careful, it empties the water bucket quick at full in gear. Then get to lake and crank it open, barely gets faster than idle. In neutral it will rev up, but in gear on water, will not. Where do I go from here? When I first got the boat/motor, it never broke any speed records, but would rev up. Thought I had drag due to some holes on the aluminum strakes, but plugged up and still same.
The feedback I got here was dead on. No fire on my lower cylinder. I thought I checked spark good, but did not. Called Franz Marine (Also in some chains on here as place for parts), he had a set of points and I ordered them. Installed last night and started up. Both firing and running smooth. Next check is on the water but looks like I am all set! Great forum!
