Cannot get water pump to cool at idle or fast idle. Getting some water streaming from water pump tell tale hole but not enough to get water to cool motor - gets hot and not water coming out with the exhaust. New impeller, and pump housing is good shape. Seems to have excessive bypass of the impeller---can blow air backwards through pump --- I put large rubber washer between stainless steel water pump plates to force water pump plate to impeller clearance to be reduced which helped but not enough. If I put larger rubber washer in, it almost stops ability to blow air backwards but cannot turn propeller shaft/water pump due to binding of water pump impeller.......Don't know what else to try. Anyone have any suggestions?
