Hello all
I have a Johnson 65hp 1972, after running the motor I have noticed an oil leak coming from somewhere close by the engine as opposed to by the gear box end. If I leave the motor down the oil runs down the exhaust housing and out by the where the prop is attached. If I tilt the motor up it runs into the engine housing and out round by the choke switch.
Does anyone have any ideas what seal could be gone or what the cause of the oil leak may be. i appreciate that the description is not the best so happy to answer any clarifying questions.
I guess Im looking for a place to start in tracking down the problem so any guidance would be appreciated.
Thanks all
Thanks all
